Using Identity Verification with templates
Author Jonathan Sammons
Jonathan SammonsDeveloper Support Engineer
Summary3 min read
Learn how to apply identity verification to an envelope created from a template
    • What is Identity Verification?
      • Overview and code example:
      • Getting Identity Verification for your account
      One of the API tasks that we’ve recently seen a bit of buzz around is adding Identity Verification to an envelope created via a Docusign template. There are a few steps required to add Identity Verification to an envelope created via a template, but first let’s discuss what Identity Verification is and why you should be using it.
      Sometimes when you send an envelope, you need more security than just having the signer open the envelope through their email address. With Identity Verification, you can add various forms of verification that provide greater security to your customers and your business. There are a number of authentication methods available to choose from when using Identity Verification, including:
      • Document ID and eID Verification
      • Knowledge-Based Authentication
      • Advanced and Qualified Signatures
      • SMS Authentication
      Each of the above authentication methods adds an important layer of trust to your digital transaction and has its own varying levels of security to ensure that there’s an option that’s right for your needs. I won’t cover how each of these verification methods are different from one another here, but you can read up about them in ID Verification on Docusign Support.
      The workflow for adding Identity Verification to your template will require three different API calls to complete the process. First, you’ll want to make a GET request to get a list of all of the identity workflows available on your account and the workflowId associated with the one that you’d like to use. For these examples, I’ll be using the demo server.
      Step 1:
      Request:
      Headers:
      Authorization: Bearer {code}
      Response:
          "identityVerification": [
                  "workflowId": "{workflowID}",
                  "workflowLabel": null,
                  "steps": [
                          "name": "identify",
                          "type": "EnvelopeAccess"
                  "signatureProvider": null,
                  "inputOptions": []
                  "workflowResourceKey": "",
                  "steps": [
                  "inputOptions": [
                          "isRequired": true,
      Step 2:
      After obtaining the workflowId for the Identity Verification type that you’d like to use, you will next want to create an envelope from the template of your choice as a draft. You will create it as a draft so that it’s not sent to the recipient yet without the Identity Verification added.
        "status":"created",
        "emailBlurb":"Test Email Body (Template)",
        "emailSubject": "Test Email Subject (Template)",
        "templateId":"{templateId}",
        "templateRoles":[
            "email":"jdoe@email.com",
            "name":"John Doe",
            "roleName":"Signer 1"
      Step 3:
      After creating the draft envelope from the template of your choice, you can then update the envelope to add the Identity Verification from the first step and send the envelope to your signer using the advanced_update query parameter.
      PUT https://demo.docusign.net/restapi/v2.1/accounts/{accountId}/envelopes/{envelopeId}?advanced_update=true
          "recipients":{
              "signers":[
                  "name":"John Doe",
                  "roleName":"Signer 1",
                  "recipientId": "1",
                  "identityVerification": {
      		"workflowId": "{workflowId}",
      		"steps": null,
      		"inputOptions": null
          "status": "sent"
      If you would like to have the Identity Verification option enabled for your account, please reach out to the Docusign support team through Docusign Support and request access on your demo account.
      Jonathan Sammons is a Docusign Developer Support Engineer based in the Dublin, Ireland office who has a passion for new technologies. He’s been with Docusign for over 8 years in various support roles.
        How to Create an Azure Custom Extension App for Docusign IAM
        Author Mohamed Ali
        Mohamed Ali
