Author Zing Zai Loo
Summary3 min read
    • Why Smooth Flow?
    • The setup
    • Conclusion
    In Oct 2021, Salesforce announced that Workflow Rules and Process Builder would be retired in the near future. Building flows using Flow Builder will be the way forward where it would be a one-stop shop for low-code automation.
    Why Smooth Flow?
    Smooth Flow updates the object’s Chatter post whenever an envelope status changes. I have saved Smooth Flow for last in my blog series as it is so smooth, it applies to envelopes sent in Part 1 and Part 2.
    Example
    The setup
    Step 2: Get records
    Step 3: Create new resource
    Step 4: Update Chatter
    Author Zing Zai Loo
      How to Create an Azure Custom Extension App for Docusign IAM
      Author Mohamed Ali
      Mohamed Ali
